check engine light issue
After reading a lot of tread here it help me locate part needed to be replace in a breeze.. Now to my issue...In Short summery I got a code for 02 sensor bank 2 and p0449 evap vent solenoid........I replace part needed to get rid of check engine code...1st while am waiting for evap parts I replace the 02 and clear the code....it work and that leave me on one code to fix. I took the old one (evap *Located in spare tire area* solenoid) clean the filter a little and put it back to see if that will do the trick...it work it turn the light of then when I stop and restart it came back.....new parts came in put it on clear the code to couple cycle start on and off few time seem to be ok... next day start it clear no light after a few mmin light back agagain.. I guess I should check see what code I get this time huh.....IF the code is p0449 again what would be the issue?
Well I'm guessing english isn't your first language, as that post was very hard to follow and read. That might be one of the reasons you have no replies. If we can't understand the proble then we can't help.
With that said, I was able to make it through the post and understand the problem. Unfortunately I can't shed any light on your problem, but if you're patient someone will come along and help you out.
Keep in mind you only waited 2 hrs for a reply. This is not an instant chat room, it is a forum. Replys can take a bit, especially in the middle of the day since a lot of members are at work right now. Also, everytime you view the thread yourself it counts as a "view" on the counter, so a lot of those views ou're seeing might have been you checking back on the thread. Be patient, I'm sure your answer will come
i too got the p0499 code and i also replaced the vapor canister purge valve located on top of the spare tire and i am still getting the same code. i have a scanner and i erased the code. this is a '03 blazer. any help would be greatly appreciated
zoniah
Jun 2, 2008 08:45 AM
95_Blazer
Dec 6, 2007 09:44 AM
Deezy
Oct 25, 2007 08:58 PM
DBlaser_ca
Aug 2, 2007 04:44 PM
