checking codes without scan tool?
Old Oct 14, 2009 | 03:25 PM
jnail's Avatar
jnail is an unknown quantity at this point
Default checking codes without scan tool?
Is there a way to check the trouble codes on these blazers without having a scan tool?
with the jeep I used to have, you could turn the key off and on a certain number of times, and it would flash the codes for you on the light. I was wondering if the blazers had this too?
Old Oct 14, 2009 | 03:42 PM
rriddle3's Avatar
If your vehicle has the OBDII diagnostic system, you need a reader to access the codes.
Old Oct 14, 2009 | 05:16 PM
BlaziNator's Avatar
BlaziNator is on a distinguished road
The older systems usually used the flashing trouble codes. OBD II was generally instituted in vehicles made in 1996 and newer. However my truck is a '95 and it has the OBD II plug.
Old Oct 15, 2009 | 03:06 PM
neo71665's Avatar
only ones you can check without a scanner is the first gens with OBD1 (pre 94), the 95 and I think some 96s had OBD1.5 and require a special scanner. Some 96s and everything after 97 all have OBD2 and the scanner is easy to pick up at any parts store.
Thor_449
Apr 21, 2011 09:23 AM
Mikeinnh
Apr 20, 2011 06:21 AM
pruitt801
Jul 4, 2010 02:14 AM
gmaltese
Aug 16, 2009 08:07 PM
