Classic Blazer 4x4 Issues
2004 Blazer, 3 Button on the dash.
After reading many different threads on here, and gaining a lot of knowledge on the issue, I still cant solve my 4x4 issue.
The problem started about a month ago.. While driving at 60+ MPH a "whirring" sounds would come from the front end. Clicking into 4WD would cause the sound to disappear completely. From other threads I found out what to check and the classic problems:
I replaced the transfer case vacuum switch on the transfer case. Mine is the 2 prong, it seems like most have a 3 prong?
I removed the battery and battery tray with the car running, and inspected the vacuum actuator, which looks good. The actuator cable moves freely the inch or so it should. When someone engaged 4WD in the car so I could watch, nothing moved around the actuator. A clicking sound could be heard inside the dash, and the light switched from 2WD to 4WD.
With the car off, I squeezed the vacuum actuator and I could hear the hiss of air near the firewall, which leads me to assume there's a bad vacuum cable. If there's a vacuum leak, wouldn't the 4WD not engage, unlike what I'm experiencing? I traced a hose from vacuum actuator towards the firewall, but couldn't find where it actually goes. Any help there?
Where I'm confused is why shifting into 4WD while I'm driving is stopping the sound or having any effect at all. If the vacuum actuator isn't moving as it should, what is changing that stops the sound? This leads me to think there's more than one issue. My HVAC system is working fine.
Thanks for any help, I realize theres hundreds of threads dealing with similar issues, but I'm still at a loss.
The problem is the axle clutch is partially engaging when you're in 2WD causing the noise. Selecting 4WD fully engages the axle clutch and the noise stops.
This thread might help: https://blazerforum.com/forum/2nd-ge...working-75064/
I've never heard of a 2-prong switch for the t-case...sure you got the right one?
With the new switch installed and car running, I pulled the battery and battery tray and again had someone press the 4WD button inside, and again a sound can be heard (It seems louder and like something is actually happening?) but the actuator is not moving at all.
Is there any chance you have a switch that looks like this attached to the firewall above the distributor? It should have 2 vacuum lines and one electrical connector with two wires in it.
EDIT: Follow the vacuum line from the actuator to the vacuum switch and look for cracks or leaks.
As of this second I'm trying to pull the fill plug to see if any fluid comes out, but I'm having troubles finding it.. (embarassing). Everything I've read says the plugs should be removed with sockets, but all I can find in are these two which would need hex keys.. Are these the plugs?
Edit: Photo should be rotated 90 degrees clockwise..
Last edited by pson57; Dec 2, 2012 at 08:13 PM. Reason: Edit: Photo should be rotated 90 degrees clockwise..
