-   -   Code P0449 troubles 02 blazer 4dr 4wd (https://blazerforum.com/forum/2nd-generation-s-series-1995-2005-tech-41/code-p0449-troubles-02-blazer-4dr-4wd-59638/)
dweeber1 Jun 1, 2011 11:05 PM
I ran the ODB system check and received the p0449 code. i have bench tested the vent solenoid located in the rear and when it's disconnected air moves through, when it's connected, it's closed. so i think that it's fine.
I checked the sensor connectors on the canister purge valve (near the throttle body) and it has power. i don't know what else to do to bench test the purge valve or if i need to replace it or the vapor canister.
Thanks,
chris
