-   -   Column Shift Lever bend mod (https://blazerforum.com/forum/2nd-generation-s-series-1995-2005-tech-41/column-shift-lever-bend-mod-61499/)
SoapyTheCat 07-27-2011 08:28 AM
I've got an 02 Blazer 4X4, 4.3, Auto, column shift. Problem i've got and need to see if there is an aftermarket or easy fix to is...I've got my new KEYPORT key set. And it's slightly longer than my current key and keychains and sticks out past where the shift arm passes. A slight bend in the arm would give it more clearance. Has anyone ever had any experience with modifying the shift arm, or replacing with an aftermarket that has a differnt bend angle? Or am I just asking for trouble tryng to put a slightly larger angle in the bend on the OEM?
swartlkk 07-27-2011 12:52 PM
I don't see any problem with bending the shift lever. I would recommend removing the shift lever prior to attempting to bend it. You may damage the column if too much force is applied.
