compatible starters?
just wondering what other year starters i can use for my 2000 jimmy
pretty much any starter for a 4.3 to a 5.7
The following part number are Lester Part Numbers, you can use the following starters:
6407 earlier SD 255 6449 SD 260 same as above but higher torque 6485 SD 260 second generation of the 6449 6495 SD 260 second generation of the 6485 You can also use if it fits 3510 or cold weather starter 3733. It is alway best to replace with the unit that was designed for your vehicle but of all the choices the 6449 is your best application. |
1999 to 2004 Blazers all seem to use the same part numbers.
