Confused - Blend Door Actuator or Temperature Actuator
Vehicle - 1998 Blazer LS 4WD, manual temp/AC controls
Symptom - Heater blows or trickles hot air all the time, even when turned to the off position. Will not blow a/c cold, though a/c tests good. Hot air will blow where it is supposed to i.e. - defrost vents, floor or dash. I have read a few threads here and elsewhere, such as: https://blazerforum.com/forum/showthread.php?t=29981 and http://www.automotiveforums.com/vbul...d.php?t=574779 . If it is the temperature actuator, can anyone confirm this is replaced through the "center control panel" where the switches are located as indicated in the first thread listed? I couldn't quite tell. In addition, what is the part number and a purchasing source for the part. If it is the blend door, while I dropped the glove box, I still couldn't locate the part. I will post pictures if this is the issue. Great forum, total newbie, shade tree mechanic. Thanks for being here for us "idiots"! Mark |
No, it is definitely not replaced through the center... It is on top of the HVAC ductwork towards the passenger side, accessible by dropping the glove box down.
I have to get this thread updated. The pictures were lost in my last server move for my personal website. A/C Evap Core Odor - Here's the fix! I think those pictures show the location of the actuator though. And never sell yourself short by using such a word! |
Still confused
1 Attachment(s)
Thank you for the prompt response. Unfortunately the pictures were not available.
Do you think the problem is blend door or temperature actuator? If blend door, I still don't see how to get to it through the glove box. Here is a photo of what I see and have messed with behind the glove box. I truly appreciate the forum's expertise and assistance! |
It is further up to the right looking at your picture. If I remember correctly, you need a mirror to see it, but there is enough room to get your hands in there and with a small enough bit, you can get the screws out.
The blend door is moved by the temperature actuator. This schematic will illustrate which door performs each function: http://i11.photobucket.com/albums/a1...7_hvac_sch.gif So as you can see, you could either have a problem with a broken blend door, or an improperly calibrated or defective actuator. You could run through the recalibration procedure... I cannot look it up for you right now, but I know it has been posted before. |
Originally Posted by markrd
(Post 215567)
Mark
Originally Posted by swartlkk
(Post 215571)
Precisely! The learning curve is a little steep, I'm clinbing it myself right now, but have faith it can be overcome! :cool: |
| All times are GMT -5. The time now is 07:26 PM. |
