Convert odometer from miles to Km?
Can the odometer of a 2000 Blazer be converted from miles to Km?
Thanks...Tim |
Yes, but it requires a capable (bi-directional) scan tool to reprogram the PCM, (Tech2 with the appropriate software). At the end of April, I bought a 2004 Blazer that was built for export to Canada, (RPO codes: U19, X88, & Z49). After being imported back to the States, the cluster had to be replaced and also had to reprogram the PCM to MPH.
Originally Posted by Captain Hook
(Post 590107)
Yes, but it requires a capable (bi-directional) scan tool to reprogram the PCM, (Tech2 with the appropriate software). At the end of April, I bought a 2004 Blazer that was built for export to Canada, (RPO codes: U19, X88, & Z49). After being imported back to the States, the cluster had to be replaced and also had to repogram the PCM to MPH.
Now question for you, are second gen odo's digital display or analog? if they are digital, isnt there just a button to push to change it to KM? |
LOL Second gen face plate, (black background, white writing & numbers etc) shows the gages, speedometer etc. The face plate shows either MPH or KPH, not both, and it can be replaced, it's just a thin sheet of plastic. Disassemble the cluster, remove the needles, replace the face plate, reassemble. The odometer and shift indicator each have a logic module, and they both display digitally. The entire IPC, (Instrument Panel Cluster) is controlled by the BCM on 1998 and newer. The only buttons to push are on the Tech2 ;)
(Post 590122)
Rich, I'd MUCH rather work on 2nd gens. SO much easier to diagnose, but ya gotta have a good scan tool ;) The confusing part is remembering all the changes that were made over the years, and what year they made them. Technology is a wonderful thing, I bought a Nikon D60 a few years ago, great camera, damn thing is obsolete and I haven't even figured out how to use all of the features!
1 Attachment(s)
(Post 590122)
https://blazerforum.com/forum/attach...ine=1372363874 |
Originally Posted by burned
(Post 590253)
If you live in Canada the speedometer gauge shows both MPH and KM/H
https://blazerforum.com/forum/attach...ine=1372363874 For a scan tool, I have the Snap-on "Brick" (MT2500). |
Was just starting to look for help with my '98 LT's odometer problem. Today at start-up I had 000,000 kilometers showing. Was 147,616 miles showing when I parked it. Fiddled with the trip odometer button a few times but always got kilos not miles. I;ve been having trouble with certain dash lites being lit while driving and, more recently, the odom and PRND321 lites flickering on & off. While on I-95, I also noted that the speedo and tach were off. Should have been 60 mph and 2500 rpm (?) but showed about 33 mph and 1200 rpm instead. Made three stops before returning home and still had kilos plus bad speedo & tach readings. Funny, all gauges were fine and the false dash lites were off when I parked it yesterday! Was anxious to see whether this luck would continue this morning. Seems it got worse. Gonna read more posts to see if there are similar problems from other members. Had to comment here first.
Brian, The cluster is controlled by the BCM and it sounds like there's a poor solder connection at the printed circuit board in the cluster. Remove the cluster trim panel to expose the connector on top of the cluster. Ignition in the RUN position, gently wiggle the connector in all directions. If the instrument cluster freaks out, remove the cluster and disassemble it. The connector has 24 pins soldered to the PC board, touch a pencil soldering iron to each pin so the solder flows from the board to the pin. Might have to add a dab of 60/40 lead/tin rosin core solder.
