Converting to LED taillights
Hi everyone! I could use some help, I put LED bulbs in my 1998 blazer and the bulbs are flashing really fast (electronic flasher thinks bulbs are blown due to LED's low current draw), i do not want to put a load equalizer in the circut, i was trying to find a LED compapadle electronic flasher with no luck, if you know of an aftermaket LED compapidle flasher please post! (its a 4 terminal flasher) THANKS
dude how and why do you have so many blazers/s10's/sonoma lol
check out this site:
http://www.superbrightleds.com/tail-brake-turn.html scroll to the bottom of the page, and you'll see them. also has some important info regarding LED's and flasher relays. good luck.
Originally Posted by Nathan1991
(Post 248914)
I got mine from autozone. Just look for the heavy duty flasher for your truck.
Originally Posted by neo71665
(Post 248957)
this thread has just got me thinking (about LED's and quick flashing). when i built my car trailer, i only had the rear stop/turn lights, with a pair of marker lights @ the front corners. i redid it last Summer, replaced the damaged fenders, added another set of tun signals up towards the front, angled out so others can "see" them (they still can't see my signals, they never move out of the way!), and added 4 amber marker lights to the front side of the stop/turn signal housings, and all of the lights on the trailer are converted over to LED, but they seem to "flash" fine. no rapid pulse flashing, and the truck isn't affected (doesn't matter if i'm towing with my Burb or Blazer). any ideas why i'm NOT having any problems like you guys? (i'm using the HD relay i mentioned above):icon_doh: |
As stated, you need to buy an HD electronic timing flasher unit. Most autoparts stores will have this on the shelf. The good part is that the flash timing is controlled by an electronic circuit instead of the old thermal circuit (based on load) so it doesn't care how many bulbs you have or what they draw. The only down side is that you will not have any indication of a burnt out bulb without visual checks.
good to know swartlkk. i've been using the electronic flasher realys forever.
You can never have enough S-Series!!!!! and for the guy with the trailer, you dont have a problem because betwwen the LED lights on the trailer and the Normal filiment style bulbs on the truck it draws enough amperage to not have a problem. And thanks to everybody who supplied the helpful websites!!!
lol I agree you can never have too many, but i meant more of the how? as in space and storage? and do you drive them all like different days of the week or what haha
Originally Posted by Ryanmatt135
(Post 249821)
would luv to see some pic's of your Wildcat by the way (beautiful design for the final year). i had a "Wildcat 465" i was building up for my LeSabre before it got wrote off by a drunk driver. too bad i scrapped the doner car (was so rotten it wasn't funny), and too bad i got rid of the engine, considering how hard it is to find one now (both the engine and the car). |
| All times are GMT -5. The time now is 04:43 AM. |
