-   -   Coolant Leak Behind Front Passenger Tire (https://blazerforum.com/forum/2nd-generation-s-series-1995-2005-tech-41/coolant-leak-behind-front-passenger-tire-92412/)
Kevin Heald 05-02-2016 01:22 PM
6 Attachment(s)
I noticed the smell of coolant inside my truck as well as moisture on the inside bottom edge of the front windshield. While looking for a leak I noticed coolant on the ground behind the front passenger tire dripping off the frame near the inside of the fender well. As suggested in other posts I have checked the carpet on the passenger side floor and it is dry. Would this still be a possible leak in the heater core or something else?
richphotos 05-02-2016 01:44 PM
Could be a leak at the heater core fittings
pjf1313 05-02-2016 09:55 PM
Hopefully RichPhotos is right, but. .
Do you have AC? That spot seems to be a coolant/anti-freeze leak from the heater core dripping out of the AC condensate drain hole.
I hope Rich is right for you..
P.J.
Kevin Heald 05-03-2016 10:54 AM
I do have an AC. I checked the heater core fittings and saw no signs of leaking. If it is the heater core, could the hoses be disconnected from the heater core and spliced together to bypass it until I have time to replace the heater core? Would this also be a good test to see if the leak stops as well? That way I no for sure it's the heater core.
richphotos 05-03-2016 02:02 PM
You can bypass it for the time being, yes.
Kevin Heald 06-03-2016 07:49 PM
Bypassed the heater core and the leak stopped.
cleburne red 06-11-2016 06:55 PM
Just don't forget you have it bypassed, and all of a sudden winter sneaks up on you! Did that one time in my '73. Finally got the core changed out in like January. I was FREEZING that year!
