Coolant temp sensor
Old Jun 1, 2013 | 04:02 PM
potsy78's Avatar
potsy78 is on a distinguished road
Default Coolant temp sensor
Hey all I have an 01 Blazer. I have read posts and read posts still cannot figure out my temp sensor. It seems I may have an older engine as I have 2 temp sensors, 1 in the drivers side head and 1 in the t-stat housing. The 1 in the head is not plugged in, nor can I find the connector. The one in the t-stat housing works the gauge. Can someone clear this up for me since everything I've read said the 1 in the head works the gauge. Thanks for the info in advance.
Old Jun 1, 2013 | 06:44 PM
IIRC, 96 & newer engines only have one ECT sensor, and it's near the thermostat. Data is sent to the PCM for engine controls, and is shared with the BCM, (Body Control Module) which supplies the instrument cluster with engine data.
Old Jun 1, 2013 | 06:47 PM
rexazz2's Avatar
one can control the gauge and or can be for computer feed back
one can be for the idiot light
Old Jun 2, 2013 | 02:28 PM
midnightbluS10's Avatar
midnightbluS10 can only hope to improve
My '01 only has one in the head. The used lower intake manifold I got had one near the tstat. I didn't realize it and plugged the connector into the ECT sensor neat the tstat. it worked just like when it was plugged into the one in the head. I even used the same connector for both sensors. It was long enough to reach.
Old Jun 2, 2013 | 03:42 PM
potsy78's Avatar
Thanks for the clarification.
Old Jun 2, 2013 | 09:16 PM
cleburne red's Avatar
My '95 has two sensors, IIRC. The one in the driver side head only goes to the gauge. The other, near the t-stat goes to the computer.
Old Jun 2, 2013 | 09:31 PM
Correct, '95 does not have a BCM.
jojocarreno
May 24, 2011 09:23 AM
zakm0n
Jan 9, 2011 07:31 PM
dutchs98blazermarkIII
Apr 5, 2010 06:30 PM
MrRox
13
Dec 31, 2009 09:06 AM
mbnorton
Oct 17, 2006 11:24 PM
