cranking good, no start
Old Sep 7, 2011 | 03:04 PM
drewsblazer's Avatar
drewsblazer is on a distinguished road
alright i tried switching them but no change any other ideas?
Old Sep 7, 2011 | 03:07 PM
xgiovannix12's Avatar
did the horn work after switching them ?
also did you check the ground and connections of the pump
Old Sep 7, 2011 | 03:10 PM
the horn does still function. i will be checking the wires next
which are more common to fail? the wires inside or outside the tank?
Last edited by swartlkk; Sep 7, 2011 at 03:29 PM. Reason: *Combining Consecutive Posts* - Please use the edit function to add additional information in your post if another member has yet to respond.
Old Sep 7, 2011 | 03:29 PM
By far the ones outside the tank are more prone to failure.
On a '95, there is also an auxiliary pump power connector under the hood near the brake booster. It should just look like a single wire running into a connector. If you apply +12V to this wire & the pump still does not run, then the problem is one of three things, a faulty pump, or wiring damage on either the +12V feed to the pump or the ground source to the pump.
Old Sep 7, 2011 | 03:57 PM
any reason this wouldnt be fuel pump related? maybe due to the fact that i didnt gap spark plugs? or not having ac delco plugs?
I just checked the wires and there all in good shape and also threw in some AC delco plugs and gapped correctly but still running like poop
Last edited by swartlkk; Sep 7, 2011 at 05:09 PM. Reason: *Combining Consecutive Posts* - Please use the edit function to add additional information in your post if another member has yet to respond.
Old Sep 7, 2011 | 05:21 PM
Improperly gapped plugs or bad wires wouldn't typically cause an on-again, off-again condition.
You stated that when it wouldn't start, you couldn't hear the pump. We have to assume that by making such a statement, when it does start, you can hear the pump. That means that it is something malfunctioning in the fuel system.
Old Sep 7, 2011 | 06:22 PM
So I swapped out the fuel pressure regulator and took her a spin but still no change I don't know where to go from here
Old Sep 7, 2011 | 06:24 PM
Are you listening to what we are saying?
Why did you do that? Was the fuel pressure leaking down? If so, did you isolate the pump as described in the tech article to definitively determine that the leak was at the fpr?
Do you like wasting your time/money? Because I know I don't...
Old Sep 7, 2011 | 09:30 PM
well its going to the shop tomorrow so hopefully they'll be able to figure it out
Old Sep 10, 2011 | 12:11 AM
shop told me its the spider injectors sticking so ill take a stab at that tomorrow
