The engine itself cranks over just fine and after 10 or so seconds when you stop you can hear the engine sputter like it is trying to run?!?!
From this statement above-- I had a Jimmy once that had no ignition voltage during "crank"- only "run" - it was a bad ignition switch- I proved it by jumping 12v to the ignition circuit... Engine tried to start when I let off the key- went from "crank" to "run" - the engine was still turning when it finally saw the 12v in "run" position and would sputter as you describe..... |
Originally Posted by swartlkk
(Post 203979)
So long as you either disconnected the electrical connection to the MAF or reinstalled the intake duct work prior to attempting to start, yes, that should have been sufficient to fuel the engine for a bit.
Originally Posted by brcidd
(Post 204076)
Edit: Interesting because the original starter that I burned up I noticed that if I cranked on it, let it off and then cranked right away it seemed closer to wanting to start. Needless to say, the starter didn't care for this type of "duty" on it and actually started smoking. lol |
(Post 203914)
If it will not start with starting fluid, then you know that fuel is not the issue. I would continue on through the ignition system looking for problems. Remove your coil and ICM (ignition control module) and take them to your nearest Autozone or Advanced Auto and have them tested. Have them tested repeatedly (>10 times) to get them good and hot to expose any heat related problems.
That would seem to point to an ignition switch problem then.
(Post 204145)
That sounds like the normal functioning of the security light, however, it really depends on what side of the ignition it drops. There are typically two main ignision sources which affect different systems.
(Post 204211)
I'll be running over to Autozone tomorrow morning to get a new ignition switch. Has anyone done a write-up on how to swap one out? I have been searching (and still searching) for one but don't seem to see one anywhere. Trying to avoid buying a chilton/haynes since I'll be selling the vehicle shortly. I'll give an update tomorrow if the switch solved the issue or not. |
Not sure how much it would be like the rest of the 2nd gens. I put the book method up in the Tech Articles (DIY) section.
(Post 204225)
For anyone else, here is a link to Swartllk's write-up: https://blazerforum.com/forum/showthread.php?t=18255 |
| All times are GMT -5. The time now is 11:14 AM. |
