Community
Search
Did I kill my 4.3?
Old 02-06-2020, 08:23 PM
LesMyer is on a distinguished road
Good deal!! Congrats!!
  #52
Old 02-07-2020, 02:26 PM
Tajohns34's Avatar
Thanks.
  #53
Old 02-08-2020, 07:16 PM
Tajohns34's Avatar
Got it all back together but it runs like it is only on 5 cylinders and backfires. I don't think it is timing because I made sure it was back on my mark. I also have a good deal of white smoke but it could just be steam because it is like 30 degrees out and it was idling high. I will double check the spark plug wires tomorrow when it is light out. I marked the wires but I guess the sharpie didn't stay on there, should have used a paint pen. Once I do that I am going to go and buy some cheap oil and change it.
  #54
Old 02-08-2020, 08:58 PM
Did you check the plug electrodes and gaps before putting them in? for a W vin it should be 0.060 and for an X 0.042 iirc.
  #55
Old 02-08-2020, 09:16 PM
rexmburns's Avatar
Super Moderator
rexmburns has a spectacular aura aboutrexmburns has a spectacular aura aboutrexmburns has a spectacular aura about
Your distributor could be 180 degrees off. It's a common mistake that I've made several times with very similar symptoms.
  #56
Old 02-09-2020, 10:16 AM
Tajohns34's Avatar
Then it probably wouldn't run at all. My marks lined up so I don't know. I will figure it out.
  #57
Old 02-09-2020, 10:17 AM
Tajohns34's Avatar
I never took the plugs out. I am going to double check my firing order.
  #58
Old 02-09-2020, 06:02 PM
Tajohns34's Avatar
I had plugs 2 & 6 reversed. I swapped them and now it runs good. I actually had it running for about 5 minutes to add coolant and then I changed the oil. I used cheap oil from tractor supply and got a cheap Walmart filter. There was a little bit of crap in the oil but nothing major, and no coolant. I drove about 30 miles and I think I will change the oil again tomorrow.
Looks like an engine again.
  #59
Old 02-09-2020, 09:09 PM
rexmburns's Avatar
Super Moderator
Congrats!
  #60
Old 02-09-2020, 09:12 PM
Congrats!!!! Sounds like and looks like you did a fine job on your intake gaskets!
Quick Reply: Did I kill my 4.3?
