dielectric grease on o2 sensor connection.
Old Sep 16, 2012 | 07:47 PM
spittybays
Guest
Posts: n/a
Default dielectric grease on o2 sensor connection.
Hello all. I've been getting a circuit malfunction and no activity code from my 1,1 o2 sensor. Thinking wiring due to live data looked great, bouncing between .28 and .86 pretty fast with short trim sticking just + or - 0. Started at the top unplugged blue from the PCM sprayed boy and girl with electrical cleaner re-assembled.
Unplugged sensor, sensor side looked a bit cruddy gave both sides a good soak with spray then slapped them with dielectric grease and plugged them back together.
Voltage is now showing between .05 and .00. Fuel trims are dumping out of control +++
Could this be a result of the dielectric grease on the connector. I have always used this on my connections. Do these connectors somehow "breath". Have I done bad and if so suggestions on how to get that crap off.
THANKS!!! Jeff.
Old Sep 16, 2012 | 08:27 PM
chris015's Avatar
Ive been told never to use cleaners on 02 sensors that it can kill em. Time for a new one.
If you want,look up "3 wire o2 sensor s10" on google and enjoy a electrical heated sensor.
Old Sep 16, 2012 | 08:50 PM
joey's Avatar
joey is an unknown quantity at this point
I had similar issues with an O2 sensor. Cleaned the harness connector real well and used die-electric grease on the terminals. Popped in a new delco sensor and it's been fine ever since.
You may have a poor connection at the plug. Inspect the female end for any dirty, bent or broken pins. A new delco sensor wouldn't hurt.
Cheers!
Joe
Old Sep 16, 2012 | 09:27 PM
spittybays
Guest
Posts: n/a
Yea Chris I just cleaned up the connector end the sensor itself remains in the bung untouched.
Joey I have a new delco on my desk but I cant get the old one out, previous owner must have stripped the the thread and then tack welded it in. Need to get to no-brand muffler shop and have them cut it out and replace bung. For some reason I still think somebody told me not to use the grease on the connector but if yours is fine guess they were confused with not getting it on the business end of the sensor. Thanks Guy's!
Old Sep 16, 2012 | 09:34 PM
chris015's Avatar
before you take it to have it chopped,try a small plumbers wrench. more you pull the tighter it gets! and its got a good handle for some leverage. I use em all the time. If it snaps etc,so what? you were going to cut it off anyways right?
Old Sep 16, 2012 | 11:05 PM
xgiovannix12's Avatar
I agree with chris. If you have a new one just get a large monkey wrench with the teeth and get a nice good grip of it. Try to use a cheater pipe too and see if she would budge.
Update us on your progress.
Old Sep 17, 2012 | 08:12 AM
spittybays
Guest
Posts: n/a
Sorry monkey wrench and cheater pipe were two days ago. It's off to the Central Americans. Thanks.
Old Sep 17, 2012 | 01:44 PM
spittybays
Guest
Posts: n/a
Took the fellas 45min to get it out and that was with lot's of torching, breaker bar and lift. $60 sounds a bit high but for what they went through no problem. New delco in there now running great. Sensor was original and only started with the codes at 165g's. Guess in 95 they still made parts to last.
Old Sep 17, 2012 | 02:17 PM
glad its all fixed.
Old Sep 17, 2012 | 02:52 PM
spittybays
Guest
Posts: n/a
Ha! I would hardly say all fixed..........
tzb05
TrailBlazer GMT360/GMT370 (2002-2009) Tech
Dec 16, 2009 12:02 AM
mohawks76
Performance & Brainstorming
May 24, 2008 09:42 PM
jmberman
Mar 13, 2008 08:58 AM
djkrash
Jan 8, 2008 03:23 PM
hoffy
Sep 18, 2007 07:30 PM
