-   -   Which direction does brake pad screech tabs go? (https://blazerforum.com/forum/2nd-generation-s-series-1995-2005-tech-41/direction-does-brake-pad-screech-tabs-go-82056/)
WalkGood Oct 11, 2013 05:20 PM
Decided to change my rear pads after replacing metal brake line to rear.
Found the old pads had wear sensor facing opposite directions on same axle.
Should the screech tabs go forward (leading edge) or rear (trailing edge) on the pad. All four pads look the same BTW.
Help! It's getting dark!
toyhauler1283 Oct 11, 2013 06:03 PM
Picture the wheel rolling front the squealer should be trailing ( after the pad)
WalkGood Oct 11, 2013 07:30 PM
2 Attachment(s)
In this crude sketch , you are saying the black arrow is pointing to where the wear tabs should be positioned right?
https://blazerforum.com/forum/attach...8&d=1381537526
toyhauler1283 Oct 13, 2013 07:15 AM
Correct the black arrow is right
