door hinge spring
Hey all
I have 2 questions but since they are not related I'll start 2 threads. If this is inappropiate please combine them. Changing the left front door hinge pin, the book says to use the special tool to remove the door spring. The special tool for removing the spring ended up being a pry bar. The problem is it doesn't work for putting the spring back in. I went to the auto parts store and they never heard of such a tool. So does anyone have any tips on how to get the spring back in place. I'd hate to go to a dealer for this. Info: 1995 Blazer LT, 4 Door 4WD, Auto, 160,000 mi, 4.3L type W Vortec engine Thanks Mike |
It's called a 'Light Truck Door Hinge Spring Compressor'. "door+spring+compressor" will give you the pertinent details. Specifically this thread--> PSA Door Spring Tool
Thanks, that was quick
Mike (I need to learn to search first) |
Harbor freight sells them for like 4 bucks
big ziptie, compress the spring in a vice and then do up the ziptie to hold the spring compressed, put the spring in place in the hinge and cut the ziptie.
just a thought, ive never replaced mine but thats more or less how a spring compressor works. for suspension they use big u bolts. |
hmmm..... do you need to take the spring out to change the upper hinge? just curious cuz rly my jimmy doesn't even have a spring ffs :/
found this today after looking all over the forum. http://www.bodyshopzone.com/archives...replace_1.html
hope it helps I plan to book mark that url so I can spit it out everytime someone says the word hinge in here |
Those better be some strong zip ties! I used wire and it still took a few tries to get it to stop breaking the wire.
Best to just get the proper spring compressor. Its safer that way! |
Originally Posted by g_mike
(Post 378508)
Originally Posted by swartlkk
(Post 378544)
| All times are GMT -5. The time now is 12:43 PM. |
