Door Seal
When I got my blazer the driver side door seal was off and you can hear wind really bad from it, but no water leaks surprisingly. So I went to the junkyard and pulled one off some blazer.
My question is what type of glue should I use to seal the seal back on, as layers of electrical tape isn't holding up... Thanks. |
3M Weatherstrip adhesive #08001, commonly referred to in the industry as "elephant snot". Comes in a 5 ounce tube and most auto parts stores have it. Apply the snot to the weatherstrip and temporarily install it for a second or two and remove it. Wait 5 minutes and install the weatherstrip permanantly. Make sure you install it where you want it, 'cause it won't let go when the two surfaces contact each other ;)
Originally Posted by Captain Hook
(Post 511468)
...Make sure you install it where you want it, 'cause it won't let go when the two surfaces contact each other ;)
Suggest wearing old gloves.. REALLY! |
Sweet, thanks a bunch.
Originally Posted by pettyfog
(Post 511472)
Lol! "Do not use this product while naked and with an itch."
| All times are GMT -5. The time now is 04:45 PM. |
