dorman oil cooler lines leaking within 20 months,and i'm PISSED!!!!!!!!
[:@]i spent$66.42 plus shipping and 3 hours on my back in my driveway to install new oil cooler hose assemblies from dorman and ayear and a half latter they are leaking, just like the stock ones!
anybody else have issue with replacement oil cooler lines or dorman in general?
i want a little more info before i contact dorman![:@]
ps i installed them correctly and torqued the bolts down correctly so please don't flame on my installation
RE: new! dorman oe replacement oil cooler lines leaking within a year and a half, i am PISSED!!!!!!!!
I also had problems with the Dormans I replaced about 2 years later they started leaking so i made my own hoses with 3000 psi pressure hoses and brazed the fittings. It been bout 2 years since and there are no leaks.
cool thanks for the reponse man, i just got done emailing them with my problem
interested in how they resond!
The Dorman lines used to be the best you could buy, given the crappy overall design.
I too have brazed on fittings and had hydraulic lines made up to make the bends.
i might have to go that route
ORIGINAL: DlJr82
pics, no but a search should pull up everything you need, but whatever you do don't get the dormans!!!!
swartlkk and dljr82 solution is your best bet
I just did a search and came up with 300 postings..lol. I guess I will just replace mine with the cheap Dormans, then take my originals to a hydraulic hose shop in town and see what they say isthey best way to fix them. That way I'll have some when the cheap ones leak. I was just wondering how they had brazed the crimps on. I keep looking through the post.
You cut the lines and then braze on fittings to adapt to the lines you have made up.
lol..ok.. now I understand. I was thinking that you were brazing the crimp fitting on before it was crimped, but that would serve no purpose. At least I think I understand what you are talking about now, you brazed fittings at the mounting blocks, right?.
