-   -   Drive without front cv axle's? (https://blazerforum.com/forum/2nd-generation-s-series-1995-2005-tech-41/drive-without-front-cv-axles-54724/)
jorg 01-28-2011 12:24 PM
My 1997 LT Blazer has a bad right front CV axle with rumbling noise from 60KM/H....
I never drive in 4x4....good roads in Holland :icon_angel:
Can I remove the 2 front CV axle's and drive it ?
Greet from Europe :icon_wink:
dobyken 01-28-2011 12:27 PM
One of the "Real" experts can correct me if I'm wrong but I believe that the CV shafts help hold the wheel on.
lynnboy021 01-28-2011 01:38 PM
sure you can remove the front diff also if you want, but you have to cut the boot on the cv and pull them apart where you put the nut on, and clean it then put it back on the hub and tight the nut. you can sell the front diff to someone
swartlkk 01-28-2011 01:55 PM
Since the axle nut torque is so critical to the life of the bearing, I would not recommend running without the CV shaft installed. If you really have to, then dismantle the CV shaft down to the outer stub and leave that mounted into the bearing hub assembly.
jorg 01-28-2011 02:50 PM
OK! that will safe me a lot off money...since I have the car for 2 years now I never have used 4x4 so this is a cheap solution for me...
So if i cut the CV axle's at both sides and leave a piece about on the picture below it isn't a problem to drive the Blazer........
http://i195.photobucket.com/albums/z...to_cv_axle.jpg
Ryanmatt135 01-28-2011 03:13 PM
Correct, that will work. if you do remove the nut/shaft, when you reinstall the nut make sure you torqe the nut to the proper torque spec to insure their is the proper preload on the hub bearing.
swartlkk 01-28-2011 05:02 PM
Just dismantle the CV joint. It comes apart once you get the boot out of there and I think a snap ring or something... It's been awhile since I have repacked one.
