Driver door hinge problem
I have rooted around looking for what the hinges are supposed to look but haven't had any luck. Here is the picture of my upper hinge. I can lift the door quite a bit as the hinge isworn out. I feel like there is a missing bushing on the top hinge on the very top. Why would the truck be designed to wear on only the metal in the hinge? Especially on welded hinges. Any input or pictures af a good hinge? It's worn on the top and bottom but far worse on top. 99' Blazer 4 dr
There's a ceramic bushing that each pin goes through. It's really common for the bushings to get worn out and break. Hopefully it hasn't ovaled out the pin hole and you can just replace the bushings. The kits are only $15 or so.
Yes, there should be a bushing in there. I would bet that it has been that way for a while and the bushing broke into pieces and fell out. Cheap fix but tough to do if you don't have a 2nd set of hands.
Where can I get this bushing? Part#? Thanks!
just go to any parts store (Advance Auto, Auto Zone, and so on) it's a common part that they'll surely have
use to be both upper and lower pins in a single kit years ago, but now it seems everyone sells them by single pin which is STUPID... but they're about $10 a pin (with new bushings and all) and you'll need two for each door
Guest
Posts: n/a
You will also need this. I tried every possible way to compress the and im a real Rube Goldberg. without it you will loose a finger!
There's a ton of write ups on how to do the whole job. In fact that's how I found this forum after I was charged $220 to do one side. Damn right I did the other side myself but mostly with the people here and on S10. Although this is the main spot.
