Driver's door seal
i just purchased a '04 Blazer ZR2. I am happy with it, but it makes a lot of noise on driver's side door, and leaks in car wash. Is there a simple fix?
Originally Posted by BiggDaddyAK
(Post 464531)
Originally Posted by bromanjr
(Post 464536)
Check your door hinges, once the bushings wear out the door seal can leak at the front. Hinge pins and bushings are very common to wear out and most Auto Parts stock the repair kit.
and buy the stupid spring tool or you'll drive yourself insane trying to replace the spring..... |
Thanks for the insight. I changed the door pins, using the spring compressor tool and it took alll of ten minutes to complete. The noise stopped and all is good. Thank you again!
Thanks guys I ve been looking for an answer as well my door doesn't leak but I do get a lot of wind noise
it's all about the spring tool! Had to go to three parts store to get it....about $26
