-   -   Drivers door wont lock with remote. (https://blazerforum.com/forum/2nd-generation-s-series-1995-2005-tech-41/drivers-door-wont-lock-remote-53427/)
dustinhxc 12-31-2010 11:26 AM
All of the doors lock with the remote except the drivers door. I have to manually lock it with the door lock button on the door before I close it.
1999 GMC Jimmy Thanks!!!!!!!
swartlkk 12-31-2010 01:38 PM
You have a problem with the door lock actuator on the driver door. Take the door panel off and check for proper power and ground at the connector to the door lock actuator when the lock & unlock buttons are pushed. If that checks out ok, then the actuator is at fault.
dustinhxc 01-01-2011 04:10 PM
Thats what I was thinking it would be, thank you I will look!
