Community
Search
Eating gas like crazy!!
Old 03-07-2014, 01:53 PM
4x4Sandman is on a distinguished road
Originally Posted by spittybays View Post
If you want easy and cheap there is a two part kit for muffler repair that will work. Its white tape with a tube of goop you soak it then wrap it around. Ad some epoxy hardener to the goop and it will set off faster without the heat of the exhaust.
I already replaced the cat and i replaced the fuel fuller today so if it keeps burning gas ill start trouble shooting the plugs wires and distributor.
Old 03-08-2014, 06:31 AM
JavierEscalonJr's Avatar
JavierEscalonJr is on a distinguished road
My 96 was getting like 8 gallons a mile I changed everything was still having that problem so I hooked up my code scanner and it said it was an o2 sensor, didn't see the ses light because the bulb burned out, just another thing it could be.
Old 03-08-2014, 06:14 PM
Chic_Bowdrie is on a distinguished road
With all these problems and no DTC? Maybe the SES light is burned out.
Was the leak down test successful?
Old 03-09-2014, 02:38 PM
My light was burned out i just checked it and it is the o2 sensor and cylinder 3 is dead due to the distributor cap being burnt out. So im gonna doba full tune up cause i just bought it so i wont have to worry a obout the ignition sys for a while
Old 03-10-2014, 07:02 PM
spittybays
Guest
Posts: n/a
Keep us posted.
I will be hated, not the first time. If you can't afford Delco buy what you can. Your fuel savings will make up for it in no time.
E-bay has cap's and rotors, Chow-Mien style for like $12. I just order two sets and after 50G's just get two more.
Sorry guys I'm a big ducked tape man. 200G's and only one fuel pump has failed to start.
I did use a Delco on the pump.
Old 03-11-2014, 02:05 PM
Keep us posted.
I use 1aauto.com for all my parts and have never had a problem with them. I did do the full tune up and replaced both o2 sensors and she runs like shes brand new.
Old 03-27-2014, 05:26 PM
thercholic is on a distinguished road
State inspection just said I need new fuel tank, because lock ring is rusted and leaking. Don't want to take tank off until I know if that's really it. Problem is the tank is plastic, and I wonder if the lock ring is a seperate replacement part. It could even be the fuel line, how can they see top of tank anyway? Do you know if lock ring, weal, etc are separate from the tank, and the tank may not be the problem?
Thank, Mike
Old 04-23-2018, 03:23 AM
ladydawg82457 is on a distinguished road
Originally Posted by 01xtreme_chevy View Post
Have you checked your distributor cap/rotor, plugs and wires?
My 2002 Chevy Blazer is only getting 80 miles PER TANK OF GAS. help
megaroos_00
05-04-2010 06:39 PM
nonblazing4x4
25
05-28-2009 05:00 PM
mudd
05-14-2008 12:02 AM
EuroGoldLS
Street N Strip
78
04-11-2008 04:06 PM
Quick Reply: Eating gas like crazy!!
