-   -   ECU problem (https://blazerforum.com/forum/2nd-generation-s-series-1995-2005-tech-41/ecu-problem-30380/)
tatkinson1981 May 9, 2009 04:46 PM
ECU problem
:confused: i have a 99 LT, when i bought it the check engine light came on, come to find out it was the vaccum hose that connects to the left inner fender. When i took it to the shop the scan tool couldnt connect to it. I then took it to another shop there scan did the same thing. what do you think it is.
swartlkk May 9, 2009 05:44 PM
Is your cigarette lighter working? The DLC is powered off of the same circuit as the cigarette lighter. If the fuse blows for whatever reason, a scan tool will not be able to connect with the vehicle.
