Emissions.
With all due respect, A "dead" or "poisoned" converter is the result of another problem, not the root cause. If the converter is subjected to excessive HC levels for an extended period of time, it will destroy the converter. Replacing the converter without repairing the root cause, (incorrect fuel mixture) will result in the replacement converter failing as well. This link explains the possible causes and what effect they have on the four emission gasses: http://www.autoshop101.com/forms/h56.pdf
What does your engine look like?
This is CMFI. It was by far the most common engine used in 1995 S/T series vehicles. There were two different computer control systems used on this engine:
This is CSFI. Very few, (late production) were installed in 1995 S/T series vehicles. It has a totally different computer control system:
OBDI systems, (mid 1995 and older) you can jumper 2 pins in the port to retrieve the DTC's. The DTC's on your vehicle must be retrieved with a scan tool. You'll need to find a shop that has a scan tool that will communicate with your system. Call around to local shops and explain what you have. Your system is inbetween OBDI and OBDII. It has an OBDII, (1996 and newer) type port under the dash, but the vehicle is not fully OBDII compliant with emission requirements for 1996 vehicles. Wish I had better news, but it is what it is
