engine running lean bank 1 and bank 2
Old Nov 15, 2010 | 11:04 PM
FOGEL's Avatar
FOGEL is on a distinguished road
Default engine running lean bank 1 and bank 2
Well here's whats going on, i just replaced the fuel pressure regulator and fuel pump since my engine was misfiring got that all solved. Now my service engine light turns on every now and again for a couple hours or a day, the codes that were read were Engine running to lean bank 1 and engine running to lean bank 2. When i go from a dead stop every now and again it will slowly accelerate and wont build up RPM's easily but when it does it runs fine. its not running rough at all. i took starting fluid and sprayed it around the intake to see if it were a leak somewhere up there but everything seems to be fine up there. what could this be?! please help asap this is my daily driver!
Old Mar 25, 2013 | 09:02 AM
Sonny615's Avatar
Sonny615 is on a distinguished road
Was wondering if you ever got it fixed? I have same issue. Thanks
Old Mar 26, 2013 | 07:24 AM
AndrewO1991's Avatar
AndrewO1991 is on a distinguished road
well, running lean could be a vacuum leak. Or air getting in the intake anywhere behind the mass air flow (check the plenum). If the regulator was only replaced and not the injectors as well that might be why. The injectors may not be up to par.
markjr390
Mar 13, 2011 08:51 PM
FOGEL
Dec 10, 2010 08:52 AM
Jonas
Jan 12, 2010 02:34 PM
portcqb
Sep 2, 2008 05:06 PM
4lowlife
Engine & Internal
Feb 18, 2007 12:40 AM
