EVAP Problems.
EVAP Problems.
This was the 1st code my 2001 blazer threw out
P0440 Evaporative Emission Purge Control Solenoid Damaged.
This is the 2nd code my 2001 blazer threw out (I have gotten this code 4 or 5 times so far)
P0446 Evaporative Emission Control System Vent Control malfunction.
1. I replaced the gas cap. Got it at Autozone. Worked for 2 weeks then "Check Engine Light" Came back on
2. I also replaced the Purge Valve. Worked for 1 day. then "Check Engine Light" Came back on. I got the code removed from the computer. It was this code again. What could be causing the "Check Engine Light"to keep itcomingback on?
Any ideas?
Kevin From Shelton (Quinnman105)
Any ideas?
RE: EVAP Problems.
P0440 is a generic Evap system code and doesn't necessarily point to any one component in the system.
P0446 however points directly at the vent valve as you have noted. I see that you have replaced the purge solenoid on the engine, but have you had a look at the vent solenoid under the truck? For a 4dr, it is located on the crossmember directly ahead of the spare tire. There are quite a few posts on the vent (purge) valve floating around, let me see if I can find one with the relavant information.
EVAP Vent Solenoid - Part Number?
Then there is a thread that you posted in quite some time ago... Service Engine Soon light... Code P0440
So you replaced the purge valve under the back of the truck and are still getting these codes? If so, then you may have either a faulty vacuum line between the engine and evap system / fuel tank at the back of the truck... The next step for diagnosis is a smoke machine pressurization of the fuel tank & evap system to look for leaks.
RE: EVAP Problems.
Kyle,
I just went to rockauto.com and I just ordered the Vapor Canister Purge Valve and is listed under PN 214633.
Thanks For your helpful information with the PN & Correct Part Name
Kevin
Kevin
RE: EVAP Problems.
Well, what part was it that you replaced already?? Was it the purge solenoid on the engine?
RE: EVAP Problems.
The part I replaced was On the Engine
RE: EVAP Problems.
It was NOT the Vapor Canister Purge Valve. I replaced the Purge Valve in the engine
RE: EVAP Problems.
Gotcha, that is what I was thinking. So yeah, the vent valve under the truck should do the trick for ya.
RE: EVAP Problems.
I hope this solves the problem.
EVAP Problem Continue!
This is the latest....
The NEW Vapor Canister Purge Valve won’t work with the current set up on the truck. The old Vapor Canister Purge Valve looks to be a little longer than the new one. I can try to send pic of the (2) different looking ones.
Any ideas?
Kevin From Shelton
Any ideas?
Kevin From Shelton
RE: EVAP Problem Continue!
*Moved to 2nd Gen Tech*
I responded to your PM. If you can, snap a picture of the two valves side by side. I know that the PN that I have listed in a few other threads, including this thread, worked without issue on my '00.
mayor28
12-02-2010 01:03 PM
JudOWNED
01-26-2010 09:18 AM
