Evaporator Case Disintegrating
I have a 95 GMC Jimmy and I've just noticed my Evaporator Casing on the fire wall is falling apart. Its all dried out and literally falling to little pieces. Are these parts still available and what is involved in changing them out?
Thanks |
there is an exterior case that does this, dont worry about it unless it is in fact the inner most case, which will leave the aluminum evaporator core exposed.
But as far as the case goes, join the club lol. They all do this |
Originally Posted by AndrewO1991
(Post 593600)
if you want, it wont hurt either way. It will just fall out on the road. Worst case is the exhaust but it wont be set ablaze or anything. Just melt alittle till it is small enough to fall out
(Post 593605)
dont bother replacing it. it really isnt needed as long as the inner case is complete. the outer case is just sorta "extra." the best i can figure is that GM put it there to act as a heat shield, and then later found out they dont really need it as long as the A/C is working properly. plus, if you ever have to change the Blower motor or change the heater core, you have to cut parts of it out and throw them away anyway. so why bother.
Originally Posted by Twip
(Post 593639)
Thanks a lot!!!!! |
