-   -   Exhaust Removal (https://blazerforum.com/forum/2nd-generation-s-series-1995-2005-tech-41/exhaust-removal-96079/)
Alexis_the_s10 01-10-2018 11:45 AM
Exhaust Removal
I am trying to remove my muffler from the cat pipe at the flange and the nuts on there do not move and the studs do not have a hex head how do I remove it without cutting anything? 2000 Blazer 4dr 4wd LS trim
Tajohns34 01-15-2018 05:26 PM
That flange should have nuts and bolts on it. You can try heating them with a torch or you might have to cut them out. I cut mine and replaced them with stainless bolts.
christine_208 01-15-2018 05:55 PM
I was able to take mine off with a socket and a breaker bar. One of the studs broke but that was on the part I was replacing.
oldeerslayer 01-16-2018 05:45 AM
I use a small propane and oxygen torch to get the nuts glowing red. Haven't broken one bolt since going to this method. Previously broke about half of them and they are a real PITA to drill out. Must be hardened steel.
