-   -   Found open connector near BCM do not know where it goes... Any thoughts? (https://blazerforum.com/forum/2nd-generation-s-series-1995-2005-tech-41/found-open-connector-near-bcm-do-not-know-where-goes-any-thoughts-36293/)
tazz9690 10-26-2009 08:26 PM
1 Attachment(s)
Hey guys, I was removing my overflow reservoir to clean it out because it had that brown sludge built up at the bottom. While I was unbolting the BCM from the resevoir I noticed this connector that was disconnected and I cannot figure out where it goes. I was wondering if any of you can point me in the right direction. I have attached a thumbnail of what I am talking about. Ever since I had my 02 Blazer Xtreme, the headlights never worked. Could this be the connection to the BCM that is preventing the lights from grounding? Thanks everyone who takes the time to look through this.
midnightbluS10 10-27-2009 07:29 AM
The ECM is bolted to the reservoir. The BCM is located in the cab.
Not sure about that plug. I'll check AllData when I get to school in a little while.
swartlkk 10-27-2009 07:51 AM
It looks like it is just plug terminated meaning that it has a dummy sealed plug installed into the end of the connector. It likely is for a feature that you do not have.
Bejaran 08-21-2019 10:01 PM
Anyone know “feature”/use of connector? I recently discovered it also (2dr 2wd ‘02)
