-   -   found a vacuum hose near the oil filter, need help!! (https://blazerforum.com/forum/2nd-generation-s-series-1995-2005-tech-41/found-vacuum-hose-near-oil-filter-need-help-79376/)
er0ck273 05-19-2013 06:49 PM
when i was checking my oil filter lines for leaks, i noticed a vacuum hose dangling down. it wasnt cut straight, like the tip was angled off at maybe a 30 to 45 degree cut. what could it be from? or is it supposed to be just randomly dangling?
abig84 05-19-2013 07:56 PM
could be for the 4wd switch back at the transfer case. if you get time post some pictures that might help people figure out what it is
er0ck273 05-20-2013 07:30 PM
i have the pictures ready to go. everytime i try adding them as an attachment and uploading it, it says uploading please wait...then that box goes completely white and eventually exits...i dont get it
richphotos 05-20-2013 07:45 PM
Does your 4wd work? if it does, its not anything to do with that.
coolasice 05-20-2013 07:50 PM
more then likely from your secondary air injection pump valve....
er0ck273 05-20-2013 07:54 PM
im going to go check the 4wd right now. i just heard the horror stories of getting it stuck in 4wd lol, only one way to find out
er0ck273 05-20-2013 08:04 PM
the 4wd works perfectly, i forgot how much of a punch it packed lol. now saw it was the secondary air injection pump valve, what affects would i be expecting?
coolasice 05-21-2013 06:31 AM
only effect would be a vavuum leak and a ses light on
