Freeze Plug Replacement
Old Jun 28, 2017 | 11:43 AM
sabre420's Avatar
sabre420 is on a distinguished road
Default Freeze Plug Replacement
My 96 blazer has a bad coolant leak from a freeze plug. It's the one on the passenger side of the engine closest to the engine mount. Does anyone know how I can replace the plug without pulling the whole engine?
Also, I've heard at least 1 of the freeze plugs is completely impossible to replace without pulling the engine. Is this true? This truck is a beater and not worth the effort to pull the engine.
Old Jun 28, 2017 | 12:17 PM
abig84's Avatar
theres one or two freeze plugs behind the motor inbetween the motor and the transmission so you would probably be better off pulling the transmission if those are leaking.
if its behind the motor mount i doubt you have to pull the motor you probably just have to disconnect that motor mount and lift the the motor up a hair and just remove the motor mount and anything else thats in the way. this sounds familiar to me as i think ive done one before but its been a while.
Coddrick
May 11, 2012 10:52 AM
Red 96'
Dec 14, 2010 08:24 PM
boulonman
Mar 5, 2007 05:10 AM
MarkH
Engine & Internal
Mar 1, 2007 06:01 PM
