Front differential
Old Sep 27, 2007 | 03:31 PM
AL's Avatar
AL
AL is an unknown quantity at this point
Default Front differential
The guys are great here,they helped me out with my 2002 blazer 4x4 front drive shaft spinning in 2 wheel drive,the cable was siezed up and it was stuck with the front differential engaged.My question now is i drove 2500 miles on a trip at 70 to 75 miles per hr and i have a whinning noise,and on take off till about 50 mph it has a noise with wheel rotation with the front differential in netural,now i took off the cable.Do you think i could have damaged the front gear box.
Thanks Al
Old Sep 28, 2007 | 12:30 PM
Hanr3's Avatar
Default RE: Front differential
Not sure I understand your question?
The whir noise could be from your front actuator being partially engaged. I had the same problem on my truck. It would whir after driving on the interstate for a while. Slow down or turn the engine off and the noise went away. My fix was replacing the vacuum switch on hte t-case. After driving for a while the switch would move becuase of engine vacuum. It was partially engagein g the front diff.
Old Sep 30, 2007 | 05:25 PM
AL's Avatar
AL
I found the noise problem,it was the right carrier bearing in the rear differential,i am going to rebuild it,i only had 83000 kls on this 4x4
Drew4711
Oct 6, 2012 12:47 PM
98BlazerLT4x4
Mar 4, 2008 06:00 PM
kirmml
Oct 4, 2006 10:09 PM
dion21379
Mar 24, 2006 03:17 PM
lilred67ddgt
Dec 7, 2005 02:55 PM
