-   -   Front Differential Cable Not Staying Attached at Differential End (https://blazerforum.com/forum/2nd-generation-s-series-1995-2005-tech-41/front-differential-cable-not-staying-attached-differential-end-17927/)
98BlazerLT4x4 03-01-2008 03:01 PM
First post...
I just got a '98 Blazer and the 4 wheel drive did not work. Thanks to these forums I traced the problem to the vacuum switch on the transfer case and I thought I was ready to go now that my actuator is working and the cable is being pulled. However, the front axle still didn't lock up. I found that the cable was not attached at the differential end, and therefore the fork was not being pulled. I pushed it back in but it will not stay in when the cable is pulled by the actuator.
Is the retaining clip available from the dealer? Should I buy a new cable and try that out?
Thanks for any suggestions.
98BlazerLT4x4 03-04-2008 06:00 PM
RE: Front Differential Cable Not Staying Attached at Differential End
I replaced just the clip that hold the cable it works fine now. The clip was $9 from GM lol.
