Front driveline rotating?
from what i have found from the search function from this site, is that the 4 button np236 transfer case does turn all the time, so the front driveshaft will turn all the time, im not sure on the other transfer cases...
With the NP236 (4-button) transfer case, the front output will always turn due to the preloaded clutch inside the transfer case.
The front left wheel being always connected & thereby causing the front driveshaft to spin is not entirely true. In an NV231 or NV233 transfer case, the front output does not really spin (condition/age/etc of the vehicle aside). The reason for this is that, with the passenger side shaft disconnected in the front axle, the spider gears inside the diff will spin, but there really isn't much motivation for the entire ring gear to spin when in 2HI with either of these transfer cases.
Well I checked out the neighbors and his also spins all the time. Just tryin to figure out why that driveline is resting on the notch cutout thru the crossmember now. Started making noise and that is the only thing I see. You can see where its touching and a clean mark.
Ok so I just cant figure out why the driveline is rubbing on the the transmission crossmember. It looks like its slightly to the passenger side of the notch and it is rubbing on it. We did the transmission a month ago and you would think this should have done it right away. We put in a new tranny mount no difference. I dont think I put the transfer case on wrong cause it seems like it would be way up in the body then. Anybody got pics of that area?
