-   -   Front end wobbling at 70 mph+ (https://blazerforum.com/forum/2nd-generation-s-series-1995-2005-tech-41/front-end-wobbling-70-mph-70821/)
madblazerowner 05-18-2012 03:53 PM
Ok here we go again...got a 2000 4x4 4dr just recently changed the whole abs system master cylinder because front brakes were engaging when hot......now anything below 70 mph does fine around town get on the highway 70+ they get hot and its starts to wobble until I pull over let cool then keep under 70 and does fine...is this a abs issue
madblazerowner 05-18-2012 05:19 PM
Also changed brake hoses on both sides...no ses or abs lights.....thought I had it fixed till I got on the highway
05-19-2012 09:59 AM
Any chance you lost a wheel balance weight and the problems are not related?
madblazerowner 05-19-2012 11:26 AM
Possible but front brakes are REALLY HOT not just warm
05-19-2012 12:07 PM
Do both wheels heat up, any heat up before wobble or just after. Hands of wheel at say fifty does it track true.
madblazerowner 05-19-2012 04:29 PM
Yes both heat up before and after....after the wobble I noticed the brakes are really touchy just a slight tap and it wants to lock up but soon as it cools down not so touchy...havent changed calipers yet someone told me that if they release when cool theyare working fine have changed everything but front calipers and rotors I was trying to avoid spending anything till I solved the sticky brake situation
war00 05-19-2012 05:58 PM
im thinking wheel balance issue/alignment and for the brakes heating up seized calipers.
madblazerowner 05-19-2012 09:11 PM
If the front brakes got REALLY HOT could they warp the rim
war00 05-20-2012 09:11 AM
i cant say its not possible because i have seen that happen on transit buses, but that was a complete brake melt down failure. the rim/wheel may have hit something and is bent. if you think your brakes are over heating get a laser temp gun and go for a good drive stopping and checking the brake temp as you go.
madblazerowner 05-20-2012 10:51 AM
Just replaced calipers (cant hurt) fixing to bleed then drive.....noticed the rotor was really loose on the drivers side in comparison to the passenger side...looks like its missing the little retaining clips that hold the rotors on would that cause an issue
