-   -   Front Hub size (https://blazerforum.com/forum/2nd-generation-s-series-1995-2005-tech-41/front-hub-size-69841/)
r0k0 04-10-2012 08:29 PM
Front Hub size
What is the size of the front hubs with the electric 4x4 ?
thanks
swartlkk 04-11-2012 09:58 AM
Could you be more specific?? Are you referring to the size of the front axle retaining nut? If so, it is a 36mm nut.
r0k0 04-11-2012 07:44 PM
nop the hub, where the rims sits to make sure the opening from the new rims will fit
Hub, where the axel are held by the nut
mrkevinmjr 04-11-2012 08:31 PM
are you taking about the center bore.... ?
r0k0 04-11-2012 08:33 PM
yes sir !
mrkevinmjr 04-11-2012 08:42 PM
i beleive its 2.785 in. as per
Chevrolet / Chevy S10 Pickup Original Wheels & Rims For Sale;
mrkevinmjr 04-11-2012 08:43 PM
but then again there are also rims there at 2.765 in....
r0k0 04-11-2012 10:33 PM
sweet some i can have the rims i've been eying for a while :) they have 3" hub center bore
swartlkk 04-12-2012 08:06 AM
Hopefully they come with the proper spacers. It's best to have hub-centric rims rather than lug-centric as hub-centric is much stronger.
r0k0 04-12-2012 09:28 AM
i will buy some hub rings for it to fit good
