-   -   Fuel Filter Stuck (https://blazerforum.com/forum/2nd-generation-s-series-1995-2005-tech-41/fuel-filter-stuck-74420/)
chrisjensenjr Oct 11, 2012 02:14 PM
Fuel Filter Stuck
Upon attempting to change the fuel filter, I was not able to remove the filter from the rear fuel line. It is old, and very stuck. I tried spraying some penetrating oil but still nothing. Does anyone have any tips or suggestions? I don't want to damage the fuel lines.
BACKGROUND: I have a '99 chevy blazer with 197K. I bought it with 97k on it and the fuel filter has not been replaced since I owned it. I relieved the pressure at the port behind the throttle body and was able to get the quick connect off without a problem. But the connection from the fuel line to the back of the filter is absolutely stuck.
Any suggestions are greatly appreciated!
1sttimejimmyowner Oct 11, 2012 02:42 PM
I just faced the same problem on my Jimmy,I tryed every kind of penetrating oil thats made,used line wrenches and still couldnt get them to budge.I finaly just cut the lines and flared the ends.Then got some rubber fuel line and spliced in an inline fuel filter.It was alot easier than fighting rusted,corroded fittings that wouldnt budge.
newguy Oct 11, 2012 05:01 PM
Like it. Thanks
Captain Hook Oct 11, 2012 05:48 PM
Cut the steel line with a tubing cutter and use this: Buy Dorman - OE Solutions Steel Fuel Line Repair Kit 3/8 Inch x 18 Inch with 16mm Fitting 800-153 at Advance Auto Parts When you put it back together, use antiseize on the flare nut threads ;)
nunya Oct 11, 2012 06:16 PM
1 Attachment(s)
pair of these gets most really stubborn ones loose for me.
Attachment 32492
Irwin who now owns Vise Grip brand just calles them "Locking wrenches" no fancy name. that plus some lube and I've gotten tons of rounded off and put on by Shrek using a breaker bar line fittings.
1sttimejimmyowner Oct 11, 2012 06:30 PM
Nunya
who sells that tool?
nunya Oct 11, 2012 06:39 PM
I would assume any auto parts store (and just looked on pep boys site and they are 16 bucks and in stock at my local one for Irwin brand), I got my set from a tool truck years ago though.. Mine are far from as pretty as the ones in the pic
chrisjensenjr Oct 14, 2012 09:58 AM
Wow, thanks for all the replies guys! I bought a fuel line repair kit and will be installing it and replacing the filter today. Thanks again for all the help!
step66 Oct 14, 2012 04:39 PM
What suprises me is that NO ONE changes these filters! Uh:DUH! Once a year anyway!
1sttimejimmyowner Oct 14, 2012 05:02 PM
yeah I know what you meen.
Seems like every used vehicle I have purchased noone has changed the filter.Then they wonder why their truck or car doesnt run peoperly.
