Fuel Gauge Reads Empty After New Engine
Old Jun 22, 2011 | 01:47 PM
lunghd's Avatar
lunghd is on a distinguished road
Originally Posted by BlakeM
Mine also reads full after reconnecting the battery but then after about 10 seconds goes to empty. One the next startup it will show empty from the beginning.
lunghd, Is this similar to your problem?
No, mine reads full all the time except for at startup when it briefly swings down to 3/4 tank. Also rests at 3/4 tank when engine is off with key on Accessory.
Glad you got yours fixed.
Old Jun 23, 2011 | 06:18 AM
BlakeM's Avatar
BlakeM is on a distinguished road
Default Problem Solved
Originally Posted by swartlkk
Both run to the PCM. The PPL wire (circuit 1589) runs to connector C3, cavity 13 and the BLK wire (circuit 470 - was BLK/WHT at one of the splice packs)runs to connector C3, cavity 19.
I was able to take the information you gave me and perform two tests to finally solve my problem.
First, since I had previously grounded the BLK/WHT wire near the pump/sender unit, the BLK wire at the PCM should also be grounded. It was not(infinite resistance to ground) so this tells me that there is an open(break in that wire).
Second I took a long jumper wire and connected it to the BLK/WHT wire by the pump/sender unit and the other end into the back of the PCM connector. This should bypass the open circuit and reconnect every thing the way it was designed. The gas gauge did work again with this setup.
I have concluded that the connection is probably broken somewhere between the firewall and the back of the engine. As much as I would like to repair that, it is probably not reasonable to start tearing into the wiring any more(if I could even get to it). I think I will just install a permanent jumper and secure it along the wire bundle. If I solder and heat shrink the connections it should be just as good as it was originally.
swartlkk, Thank you! I could not have solved this without your help because it is impossible to figure out where something is supposed to be connected when it is disconnected.
UPDATE: While preparing to run the jumper to permanently fix the open wire I found the break. It was actually in a very accessible location on the connector at the rear of the transmission under the car. It looks like they forgot to disconnect this before pulling the engine and it pulled the wire out of the back of the connector. To fix it I just cut the wire going into the other side of the connector, solder and heatshrinked it all up and as good as new. Wish I saw that wire pulled out of the connector much sooner. Oh well at least it works again.
RMcwill@aol.com
Feb 7, 2013 11:08 AM
chevyadore
Mar 28, 2012 11:24 AM
unklemike00
Oct 4, 2010 06:44 AM
chipo022
Jun 1, 2009 03:12 PM
blazerguy22
Dec 12, 2008 07:59 PM
