Fuel Guage stopped working!?
Old Aug 10, 2005 | 02:56 PM
mac6135's Avatar
mac6135 is an unknown quantity at this point
Default Fuel Guage stopped working!?
1996 Blazer
125,000 miles
The fuel guage stopped working about 2 months ago. Now we just fill it up based on how many miles we have driven. What would be the cause of this and is it something that I can fix?
Thanks!
Old Aug 10, 2005 | 09:56 PM
mrjoeyjiffy's Avatar
mrjoeyjiffy is an unknown quantity at this point
Default RE: Fuel Guage stopped working!?
I have the same problem, when i crank it up, it will be like 1/4 to half full, then gradually it will go to full. Any help would be awesome.
Old Aug 11, 2005 | 12:22 PM
Hanr3's Avatar
It is a common problem. Mine does the same thing. Mine will show fuel down to 3/4 tank. Hold there until empty. Then I run out of gas real quick, within 20 miles. Don't ask how I know.
The problem lies in the fuel guage sending unit. Which is located in the gas tank. The only way to fix it is to replace it. I am not sure of the year, however I know that in my 2000 Blazer the fuel pump and fuel sending unit are sold as one unit. You cannot buy them seperately. How do I know this, cuase my gas tank is sitting on the ground under my truck until tomorrow when I can get a new unit. Heres the kicker. Depending on where you go, and which version of the unit you need, the price ranges from $260-$450. Shop around and get a lifetime warrenty. There are two version available for the 4drs. The only way to identify which version you need is by the tag on top of the fuel pump/sending unit. Which happens to be on top of your gas tank. So the only way to get that info is to drop your gas tank. Then call for parts and hope the cheapest place in town with a lifetime warrenty has one in stock. Otherwise you wait until tehy can get it in or pay more.
Dropping the tank itself isn't hard or time consuming provided it has 5 gallons of gas or less in it.
Mine has 2 bolts hodling it in place. 15mm deepwell socket. 6 hoses and 2 wiring harnesses. I have found the easiest way to remove the rubber hose is by spraying it with PB-Blaster. It will soften the rubber so you can pull it off the fitting it is stuck to.
By the way most places (Autozone, O'Rielly's, Advanced Auto, Napa) are in the $260-$330 neighborhood. Dealer was in the $400-$450 neighborhood.
Old Dec 25, 2005 | 02:20 PM
jodust11's Avatar
jodust11 is an unknown quantity at this point
I have the same problem and have encountered the same issues for this part. I checked dealerships, advance auto, auto zone and nappa for the parts and unless you are willing to pay in the neighborhood of $400 - $600 you can't even get it due to back order of the lower priced pumps. I found a brand new ac delco pump with gm 1 yr warranty on ebay for $130. The same part that I found for over $300 at the parts stores. They have them for the 2dr and 4dr versions. Grab it while you can!!!! Complete fuel pump assembly, nothing else to buy. Hope this helps. I've done a lot of business with EBAY with no problems. Shipping was $9.00 and the guy is a fast shipper.
Old Dec 25, 2005 | 04:13 PM
ivannj's Avatar
ivannj is an unknown quantity at this point
I too have the same problem and use the trip odometer two let me know when to fill. Well my question is does this mean i am going to need a new fuel pump?
Old Dec 25, 2005 | 08:00 PM
ivannj's Avatar
damn that guy on ebay had delco pumps for 125 might as well buy one just to to get that good deal.
Old Jan 14, 2006 | 12:01 AM
Labinnac's Avatar
Labinnac is an unknown quantity at this point
OI!!! I have this same problem, i just go off the trip miles to know when to fuel up.
Old Feb 18, 2006 | 09:23 PM
joebeyer's Avatar
joebeyer is an unknown quantity at this point
This problem must be common for all Blazers. I own a '99 LS and the other half owns a '00 LT. The fuel gauges start fluctuating after indicating 3/4 of a tank and then show full. Like everyone else here, we use the trip meters to refill the tanks, and don't bother with the gauge. Oh yeah, don't depend on the "low fuel' light to come on. I've only seen it come on once and have put 16-17 gallons in the 18 gallon tank with no light. The only time I see the light is during start up.
Old Feb 18, 2006 | 09:43 PM
blazerscooby's Avatar
blazerscooby is an unknown quantity at this point
now you tell me lol Yeah i had to foot it to the gas station and buy a can and gas for my blazer. the light never came on but i was oviously out of gas. cause it sayed putt putt. i learned after that day to not let it run that low again. my legs were tired lol
Old Dec 8, 2007 | 09:18 AM
CamaroManBlack's Avatar
CamaroManBlack is an unknown quantity at this point
Mine had this issue when I bought it...sending unit was replaced but it didn't fix the problem...turned out to be a chafed wire under the dash
01blazer16
Jun 1, 2013 08:41 AM
01blazer16
May 28, 2013 09:05 AM
UK Chevy
Apr 12, 2013 08:42 AM
David Hineline
Aug 20, 2010 10:07 PM
