-   -   FUEL INJECTORS - UGH! (https://blazerforum.com/forum/2nd-generation-s-series-1995-2005-tech-41/fuel-injectors-ugh-14568/)
LittleT 11-19-2007 02:31 PM
Can anyone help me?
I just replaced an injector on my '97 4.3L, put everything back together and when I went to start it ... there was a POP and wouldn't start. [:@] Hmmm ... the injectors where routed correctly. I put the retaining plate back on, so I doubt an injector would pop out the spider. But I'm not sure. It doesn't want to start correctly. :(
Also, when I received the spider assembly I purchased, it was an updated assembly to electrical injectors instead of mechanical. If I put these in is there any other conversion pieces I have to add? Or can I just plug 'em in????? The set up is the same ...
hernandez3674 11-19-2007 06:34 PM
RE: FUEL INJECTORS - UGH!
i take it you bought the MFI replacement unit.. take a look at the file attached and verify installation was done correctly.
http://members.shaw.ca/betterthanyou...g%20Poppet.htm
blazeofglory 11-19-2007 07:32 PM
Melanie,
Did you remove the distributor during the upgrade? ( I'm assuming you did) If so,verify that you haven't reinstalled the distributor 180 degrees out.
Just a thought.
Gator
