Fuel line o-ring sequence order?
Hello again, I am in process of reconnecting the two fuel lines to the fuel meter body on the plenum and I wanted to know does anyone know the exact correct order the o-rings/washer/spacers go back on the fuel lines? I have read several posts and they vary on the order. Is it black o-ring then washer then yellow o-ring then spacer? Does anyone have a pic of it? Thanks for any help...
2000 Blazer 4.3l 4x4 4dr CSEFI |
2 Attachment(s)
Thank-you sooo much burned. Nice pic I really appreciate it.
2 Attachment(s)
o rings
Now, where can you purchase the o rings?
This kit has everything you could possibly need to reseal the fuel metering block: Dorman - Help Fuel Injector O-Ring Seal Kit 90000: Advance Auto Parts=
That sure looks like everything is there. Thanks
spider injector
Another problem! Stud in top of spider injector that nut goes on that holds hold down plate for lines in spinning in plastic of injector. I can't tighten down nuts on plate enough. Any ideas how to fix short of changing entire injector?
| All times are GMT -5. The time now is 04:16 AM. |
