BlazeOn |
01-15-2011 01:46 PM |
Fuel Pressure Drop
Hey everyone. Like many others on here I have developed a cold start issue with my 2001 4x2 4.3l blazer. It ran fine then wouldn't start one day and I had it towed. Mechanic said it started right up for him and couldn't find an issue. I get it back and a few weeks later the same problem, wont start in the morning. I've tested the fuel pressure at the schrader (sp?) valve and have a strange problem. When I first prime the pump the gage reads ~60 psi but within one second drops to 50 psi and holds steady. Is this an issue with the pump not sustaining pressure or is there a bypass valve somewhere that releaves pressure if you don't crank the engine? Or maybe a faulty gage?
Also, I tried getting it to start with starter fluid and still no avail. Just a lot of cranking but no start. Getting desperate, any thoughts?
Thanks for the help.
