Fuel Pressure Questions, Test results inside
Old May 11, 2011 | 08:12 PM
Hank3band's Avatar
Hank3band is on a distinguished road
Default Fuel Pressure reads 0 psi til engine cranks for 5 seconds
I have a 2000 Blazer 2dr LS 60k miles.
Recently developed hard starting issue. If I let starter run it won't start. If I crank over short burst, stop, then short burst again, it starts second or third time. I installed new fuel filter a month ago. Gas gauge doesn't work.
I hooked up fuel pressure gauge tonight, with ignition on but engine not started fuel pressure only hits 35psi then immediately drops to zero.
When cranking motor the psi stays flat for several seconds then jumps to 60 psi and engine runs. With the engine running gauge reads 54 psi.
I read thru the 96+ Fuel Diagnosis here: https://blazerforum.com/forum/2nd-ge...tarting-58244/
I came to conclusion # 20, Replace pump.
Does this seem consistent with my fuel pressure readings?
I have a Delphi FG0072 Fuel Pump ordered from Amazon for $234 shipped. Should be here next week. Should I stop driving it because the motor is starting really hard? Got the Vstrom to ride in the mean time.
Thanks in advance.
Old May 11, 2011 | 10:38 PM
onder's Avatar
onder is on a distinguished road
I had the same problem with my Blazer. I was using the truck as my daily drive only thing that could happen is pump will stop working and you have to tow your truck. If i were you i would check the fuel pressure regulator. i had a problem with that too. good luck on your fix.
Klturi421
13
Mar 19, 2013 07:19 PM
PGDImpala
Nov 27, 2011 03:39 PM
ohsofly
Apr 23, 2011 10:16 AM
stflr
Aug 18, 2010 09:26 PM
zombiewoof
Feb 11, 2008 10:33 AM
