-   -   fuel pressure regulator again ? (https://blazerforum.com/forum/2nd-generation-s-series-1995-2005-tech-41/fuel-pressure-regulator-again-35379/)
male1956 Oct 1, 2009 09:15 PM
"95" s10blazer 4.3 vortex 229,000. miles... had fuel pressure regulator replaced 45,000. miles ago by mechanic $$$ ... lately been starting rough but runs good when going .... mechanic says i need fuel pressure regulator again ... can they go bad that soon ?
i'm pretty much mechanical myself ... is hard to do it yourself ? ... seems alot to remove to get to it & wondering if there's any sites that shows step by step?
Dave
male1956 Oct 3, 2009 07:03 AM
anyone ?
reelbroke2 Oct 3, 2009 07:48 AM
its pretty simple to do..unscrew the 10 bolts that hold the upper plenum in place and remove the plugs from the sensors.they are all different plug ins and only go 1 way remove the 2 vacuum hoses from the rear of the intake and 1 from the front and remove the throttle linkage and set it to the side..the fuel injector spider assembly is under the upper plenum and the FPR is held in by a torx screw on the left side of the spider
