-   -   fuel problem with fill (https://blazerforum.com/forum/2nd-generation-s-series-1995-2005-tech-41/fuel-problem-fill-36335/)
mikegav Oct 28, 2009 10:28 AM
hello im new here so i have a 2002 s-10 blazer 4wd and what has been happening is when i go to put fuel in it takes forever seems like there is something clogging the filler neck ive never had this problem with any other vehicle i owned truck runs fine other then when i have to put gas in any ideas thanks again mike
Monkeyman Oct 28, 2009 10:48 AM
I have a similar problem. When I fill it up, the auto shut off at the pump (any pump) doesn't work and gas will run out of the fill tube. I have to listen very carefully to make sure I stop the pump just before it fills completely. I'm guessing it's a blockage in the vent tube. That might be your problem, too.
mikegav Nov 1, 2009 02:04 PM
no vent problem
checked no problem with the vent just dont understand it
Blazeme Nov 1, 2009 09:21 PM
I had some trouble like this a few years back on my 01 Blazer. I replaced a solenoid, I think it is in one of the gas tank vent or purge lines. It was located in front of the spare tire.
I could not tell if it was hanging up or what. It seamed to be free to move inside and I thought it should be ok so I put it back. The tank still filled slow so I purchased a new one. After I replaced it the tank has filled normally ever since.
It is baffled to keep water out but were it is located it looked like it gets a lot of trash splashed on it.
Hope this helps
Blazeme
mikegav Nov 3, 2009 11:21 AM
thanks blazeme ill try this let you know outcome thanks again
