-   -   fuel pump again (https://blazerforum.com/forum/2nd-generation-s-series-1995-2005-tech-41/fuel-pump-again-21291/)
2drblazer 06-13-2008 09:52 AM
fuel pump again
i just bought a fuel pump and tank on the 27 of april and 4 days ago my car died ive narrowed it down to the fuel pump anyone else had this problem i herd its common and someone at work put 3 in their blazer
99 2dr 4.3
95_4door 06-13-2008 10:10 AM
RE: fuel pump again
Where did you get the fuel pump from? Also when you changed the fuel pump, did you change out the wiring harness? If not then that could be why it went out so quick. GM recomends you replace the harness eveytime you replace the fuel pump.
2drblazer 06-13-2008 10:32 AM
RE: fuel pump again
i bought the fuel pump at advanced auto i have a 1 year replacement and yes we had to change out the wiring harness but its only been 2 months and i just lost fuel pressure
swartlkk 06-13-2008 01:22 PM
RE: fuel pump again
I would inspect the patch job you did on the wiring harness. Also, AC Delco is the way to go with the pump! Off brand pumps are horrible.
swartlkk 06-25-2008 06:03 PM
RE: fuel pump again
Anyone wishing to respond, please do so by responding to the engine lacks power thread.
