Have no idea if pumps original or not. 1st time its ever failed on me, now its working fine again. I've already got the new pump, so proceeding anyway this weekend. Planing to check all the elec. connections to eliminate that possibility.
Originally Posted by dbaas
(Post 451120)
Waited another day, tried to start. Whine was there, blazer started. Quickly drove to station and put in more gas. Drove 20 miles to get new fuel pump, restarted many times. Anyway, strange behaviour, relay's are either good or bad, not intermittent. Ground connect could be culprit, but suspect its still a pump failing. Float could be failing or got stuck down causing the initial pump off condition, and prior gauge issues.
Not going to overthink it, still proceeding with replacement to play it safe. Just hard to tear into a hairy job, when its actually working ( ie..don't fix it if it ain't broke). - not always true. 'Tend to be' would be more accurate The symptoms here are classic 'bad/worn' brushes. On older Fox Mustangs over 120k it was good to carry a 2x4 x 4' to give the tank a good whap till you got around to fixing it |
| All times are GMT -5. The time now is 02:59 AM. |
