Fuel pump difference?
Does anyone actually know what it different from the 2dr to 4dr fuel pumps. You think GM would cut costs by using the same pumps.
The pump itself is the same, the housing assembly is what's different.
The tanks on S10 pickups are a different size housing also.
So I can geta4dr pump, and use the guts in my 2dr.
You might also check with Tre_Performance and order just their pump and fit it into your old housing. Their pumps (they say) meet or exceed OEM specs as they are racing engine oriented. Should cost around $100 for their kit to modify your existing housing. But if your sending unit is also affecting your gas gauge, their pump is just a pump replacement.
I can get walborow cheaper. And used pumps are $16. Thanks for the info though!
Still thinking of going with the old steel style and a high output pump.
BouncingRadical
14
11-27-2015 12:30 AM
cide
11-07-2009 01:26 PM
upblazer95
03-08-2009 07:15 PM
mytruck2
12-13-2006 04:50 PM
